I don't know wether this should be considered as bug or feature, but in
v.db.reclass and in v.to.rast (presumably also in other modules), I get no
warning when I overwrite an existing map. In terms of user-friendliness, this
might be a problem.
as far as I know many modules don't warn you (except r.mapcalc and some others)
so it would be quite a bit of work to add it, but it should be done - Markus,
maybe you should put it into the TO DO list so that developers know about it
and as modules are enhanced/updated this feature can be added
helena
subject 'unsubscribe grass5'
>might be a problem.
this is an important issue I was already thinking to add to TODO.
Currently there is no consistency. It could be added easily to
make the module ask: "may I overwrite?" - But: In script mode
we don't want such questions (or every module needs *another* parameter
to allow silent overwriting).
I am not sure what we want:
- change modules to ask for overwriting in both interactive and command line
mode
- change modules to ask for overwriting in interactive mode, but silently
overwrite in command line mode
Comment are welcome,
parameter to allow silent overwriting).
This is the ideal solution from a software engineering point of view.
That is, always ask for overwriting, but allow a command line option to
override it. Of course it would be great if we could find a value for
the option that can be consistently used for all the modules. But I have
no idea if that is possible though. I don't know how the command line
parser interprets flags, but if it can only accept single character
flags, then I would say it would be worth changing it to accept multiple
character flags just to implement this feature. Then we could choose
whatever flag we want like -ow or even -overwrite. I'm willing to change
the command line parser if we agree to this and if the parser needs to
be changed.
command line mode
Yes.
silently overwrite in command line mode
No, this mode would defeat the purpose of the warning.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
be changed.
Well, I think a flag like '-f', is pretty standard (as in "rm -rf /" !).
I don't think any change in parser behavior is required. Modules can
handle this pretty easily.
Eric G. Miller <egm2@jps.net>
