I tried working on the metadata system in (on my system)
/opt/grass/src/scripts/contrib/metadata. When I tried to save a README file
with my notes on what each file appeared to be doing, I couldn't save it. So
I checked the permissions.
Turns out that this directory (at least) is owned by user "103" in group
"vmware98"! Where did this come from?
Tracing this through:
/opt/grass root.root
/opt/grass/src 103.vmware98
This is the CVS weekly snapshot from 17 July.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
Making environmentally-responsible mining happen.
This reflects the UID/GID on the system on which the .tar.gz file was
made. I suspect that the tar file contains numeric UID/GID
information, with the numeric GID stored in the tar file being
allocated to "vmware" on your system ("tar tv ..." to check).
If you perform the extraction as a normal user rather than root (this
would require write permission on /opt, or /opt/grass if it is created
first), you will own all of the files.
I realize that the permissions come from the source machine, but I was
curious why the number. What you wrote makes sense: tar took the UID rather
than the username. However, I have no idea why the GID was picked,
apparently at random. Strange!
/opt is owned by root; whenever I install software there the entire tree
is owned by root.users.
Wierd stuff, that tar.
Rich
