[GRASS5] Patch for bug#3345 (debian bug#313307)
The attached patch should fix bug #3345 (actually g.html2man not escaping
control characters for roff). It seems to do the right thing for me. Please
test and close. I don't know how it should be resolved in the debian
bugtracker. Or in the grass bugtracker, for that matter...
Daniel.
-- Daniel Calvelo Aros
(attachments)
g.html2man.diff (227 Bytes)
Thanks for the patch!
On Tue, 2005-07-12 at 21:20 -0500, Daniel Calvelo Aros wrote:
bugtracker.
The debian bug will be closed automatically by placing a (Closes:
#313307) in the changelog when I upload a version of grass containing
the fix to the debian archive.
Steve
Patch applied. but now it looks a bit unhealthy (RHEL4):
g.manual -m v.in.ascii
NAME
       \(rsfI\(rsfBv.in.ascii\(rsfR\(rsfR - Convert GRASS ascii file or points file
       to binary vector.
SYNOPSIS
Patch the patch? Revert?
> Hi,
> bugtracker.
Steve
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
AAAARGH! Revert and ry this one instead. Silly me... I'll look futher into
where to properly escape backslashes. I'd guess a previous pass but don't have
my sources right now.
---------- Original Message -----------
To: Steve Halasz <debian@adkgis.org>
Cc: daniel.calvelo@minag.gob.pe, grass5@grass.itc.it
Sent: Wed, 13 Jul 2005 12:21:11 +0200
Subject: Re: [GRASS5] Patch for bug#3345 (debian bug#313307)
NAME
file or points file to binary vector.
SYNOPSIS
> > Hi,
> > bugtracker.
> Steve
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
------- End of Original Message -------
(attachments)
g.html2man.diff (228 Bytes)
OK, patch reverted.
Hopefully you'll find a solution!
> NAME
> SYNOPSIS
> Markus
> > > Hi,
> > > bugtracker.
> > Steve
> grass5 mailing list
> grass5@grass.itc.it
Ok, there you are. This patch does correctly escape backslashes before
processing and then re-escapes single and double quotes where they could be
active characters for roff.
I noticed that backslashes are seldom used in the docs, but on two occasions
they are intended to be actual roff escapes:
- r.mapcalc uses '\e' to denote continuation once. It uses '\' one paragraph
later for the same. I think with this patch applied the '\e' should be changed
to '\'. Note that for roff \e is the escape character, which can be changed,
whereas \(rs is the backslash glyph. BTW, the docs for r.mapcalc contain
several tables written as preformatted text, which can be rewritten as proper
tables.
- r.watershed uses both \u and \d escapes, which are roff codes for switching
on and off superscript. Those should be changed to something html-ish.
Otherwise, occurrences of '\' are for verbatim continuation lines or as
html-unescaped shell-like special characters: \t, \n,...
Hope I got it right this time. Sorry for the previous noise.
To: daniel.calvelo@minag.gob.pe
Cc: Steve Halasz <debian@adkgis.org>, grass5@grass.itc.it
Sent: Thu, 14 Jul 2005 10:32:08 +0200
OK, patch reverted.
> From: Markus Neteler <neteler@itc.it>
> > NAME
> > SYNOPSIS
> > Markus
> > > > Hi,
escaping
Please
> > > > bugtracker.
> > > Steve
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
(attachments)
g.html2man.quotes.patch (459 Bytes)
Daniel,
thanks for the new patch, seems to work fine (I tested a few
man pages).
Applied to both 6.1-CVS and 6.0-CVS.
tables.
