[GRASS5] PATCH: lib/gis compiler shutups
Here's a patch against lib/gis to mostly quiet GCC:
Index: lib/gis/ask.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/ask.c,v
retrieving revision 2.1
diff -u -r2.1 ask.c
--- lib/gis/ask.c 1 Mar 2005 21:50:46 -0000 2.1
+++ lib/gis/ask.c 23 Mar 2005 11:51:11 -0000
@@ -81,6 +81,7 @@
#include <string.h>
#include <stdlib.h>
+#include <unistd.h>
#include "gis.h"
#include "glocale.h"
Index: lib/gis/cell_stats.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/cell_stats.c,v
retrieving revision 2.0
diff -u -r2.0 cell_stats.c
--- lib/gis/cell_stats.c 9 Nov 2004 12:14:30 -0000 2.0
+++ lib/gis/cell_stats.c 23 Mar 2005 11:51:11 -0000
@@ -289,7 +289,7 @@
   return 1;
/* start at root and go all the way to the left */
     s->curp = 1;
- while (q = s->node[s->curp].left)
+ while ((q = s->node[s->curp].left))
   s->curp = q;
     s->curoffset = -1;
@@ -312,7 +312,7 @@
   return 1;
- while (q = s->node[s->curp].left) /* now go all the way left */
+ while ((q = s->node[s->curp].left)) /* now go all the way left */
   s->curp = q;
     return 1;
@@ -385,7 +385,7 @@
       s->curoffset = -1;
       continue;
- if (*count = s->node[s->curp].count[s->curoffset])
+ if ((*count = s->node[s->curp].count[s->curoffset]))
       idx = s->node[s->curp].idx;
Index: lib/gis/cellstats_eq.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/cellstats_eq.c,v
diff -u -r2.0 cellstats_eq.c
--- lib/gis/cellstats_eq.c 9 Nov 2004 12:14:34 -0000 2.0
+++ lib/gis/cellstats_eq.c 23 Mar 2005 11:51:11 -0000
@@ -7,8 +7,10 @@
     void (*func)())
     long count, total;
- CELL prev, cat;
- CELL x, newcat;
+ CELL prev = 0;
+ CELL cat;
+ CELL x;
+ CELL newcat = 0;
     int first;
     double span, sum;
     double range2;
Index: lib/gis/datum.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/datum.c,v
diff -u -r2.0 datum.c
--- lib/gis/datum.c 9 Nov 2004 12:16:06 -0000 2.0
+++ lib/gis/datum.c 23 Mar 2005 11:51:12 -0000
@@ -154,7 +154,7 @@
     char *Tmp_file;
     FILE *Tmp_fd = NULL;
     struct datum_transform_list *list, *listhead, *old;
- int transformcount, currenttransform, i;
+ int transformcount, currenttransform;
     if( G_strcasecmp(datumname, "custom") != 0)
@@ -437,7 +437,6 @@
     for (line = 1; G_getl(buf, sizeof(buf), fd); line++)
         char name[100], descr[100], ellps[100];
- double dx, dy, dz;
         struct table *t;
         G_strip(buf);
Index: lib/gis/get_window.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/get_window.c,v
diff -u -r2.1 get_window.c
--- lib/gis/get_window.c 11 Dec 2004 11:50:20 -0000 2.1
+++ lib/gis/get_window.c 23 Mar 2005 11:51:13 -0000
@@ -53,7 +53,7 @@
   char *err;
- if(err = G__get_window (&dbwindow,"","WIND",G_mapset()))
+ if((err = G__get_window (&dbwindow,"","WIND",G_mapset())))
       G_fatal_error (_("region for current mapset %s\nrun \"g.region
\""), err);
       G_free (err);
Index: lib/gis/gets.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/gets.c,v
diff -u -r2.0 gets.c
--- lib/gis/gets.c 9 Nov 2004 12:17:41 -0000 2.0
+++ lib/gis/gets.c 23 Mar 2005 11:51:13 -0000
@@ -44,7 +44,7 @@
     ctrlz = 0;
#ifdef SIGTSTP
- if (tty = isatty(0))
+ if ((tty = isatty(0)))
     sigtstp = signal (SIGTSTP, catch_ctrlz);
     if (sigtstp != (void (*)()) SIG_DFL)
Index: lib/gis/gisinit.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/gisinit.c,v
retrieving revision 1.3
diff -u -r1.3 gisinit.c
--- lib/gis/gisinit.c 30 Nov 2004 21:06:18 -0000 1.3
+++ lib/gis/gisinit.c 23 Mar 2005 11:51:13 -0000
@@ -12,7 +12,6 @@
#include <sys/stat.h>
#include "gis.h"
#include "G.h"
-#include "version.h"
struct G__ G__ ;
Index: lib/gis/icon.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/icon.c,v
retrieving revision 1.1
diff -u -r1.1 icon.c
--- lib/gis/icon.c 25 Jan 2002 10:41:17 -0000 1.1
+++ lib/gis/icon.c 23 Mar 2005 11:51:15 -0000
@@ -21,7 +21,7 @@
/* Plot icon */
int G_plot_icon (double xc, double yc, int type, double angle, double
scale)
- int i, np;
+ int i, np = 0;
     double x[10], y[10];
Index: lib/gis/locale.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/locale.c,v
diff -u -r2.0 locale.c
--- lib/gis/locale.c 9 Nov 2004 12:19:25 -0000 2.0
+++ lib/gis/locale.c 23 Mar 2005 11:51:19 -0000
@@ -6,6 +6,7 @@
#include <string.h>
#include <locale.h>
+#if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
static char *
locale_dir(void)
@@ -25,6 +26,7 @@
   return localedir;
+#endif
char *
G_gettext(const char *package, const char *msgid)
Index: lib/gis/mach_name.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/mach_name.c,v
diff -u -r2.0 mach_name.c
--- lib/gis/mach_name.c 9 Nov 2004 12:19:32 -0000 2.0
+++ lib/gis/mach_name.c 23 Mar 2005 11:51:19 -0000
@@ -13,10 +13,12 @@
#include "config.h"
+#ifndef HAVE_GETHOSTNAME
#ifdef HAVE_SYS_UTSNAME_H
#include <sys/utsname.h>
static struct utsname attname;
#endif
+#endif
char *
G__machine_name()
@@ -29,7 +31,7 @@
     gethostname(name, sizeof(name));
     name[sizeof(name)-1] = 0; /* make sure null terminated */
#else
-#ifdef HAVE_UNAME
+#ifdef HAVE_SYS_UTSNAME_H
     uname (&attname);
     strcpy (name, attname.nodename);
#endif
Index: lib/gis/opencell.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/opencell.c,v
diff -u -r2.0 opencell.c
--- lib/gis/opencell.c 9 Nov 2004 12:20:16 -0000 2.0
+++ lib/gis/opencell.c 23 Mar 2005 11:51:20 -0000
@@ -220,7 +220,7 @@
     char *r_name ;
     char *r_mapset ;
     struct Cell_head cellhd ;
- int CELL_nbytes; /* bytes per cell in CELL map */
+ int CELL_nbytes = 0; /* bytes per cell in CELL
map */
     int INTERN_SIZE;
     int reclass_flag, i;
     int MAP_NBYTES;
Index: lib/gis/parser.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/parser.c,v
retrieving revision 1.48
diff -u -r1.48 parser.c
--- lib/gis/parser.c 22 Mar 2005 15:10:37 -0000 1.48
+++ lib/gis/parser.c 23 Mar 2005 11:51:28 -0000
@@ -1422,8 +1422,8 @@
static int set_option (char *string)
- struct Option *at_opt ;
- struct Option *opt ;
+ struct Option *at_opt = NULL;
+ struct Option *opt = NULL;
   int got_one ;
   int key_len ;
   char the_key[64] ;
Index: lib/gis/quant_io.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/quant_io.c,v
diff -u -r2.0 quant_io.c
--- lib/gis/quant_io.c 9 Nov 2004 12:21:11 -0000 2.0
+++ lib/gis/quant_io.c 23 Mar 2005 11:51:33 -0000
@@ -69,6 +69,7 @@
static int quant_parse_file (FILE *,struct Quant *);
+#if 0
static int
/* redundant: integer range doesn't exist now: it is defined by
    the quant rules */
@@ -106,6 +107,7 @@
   return 1;
+#endif
Index: lib/gis/sites.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/sites.c,v
diff -u -r1.1 sites.c
--- lib/gis/sites.c 23 Sep 2003 09:00:16 -0000 1.1
+++ lib/gis/sites.c 23 Mar 2005 11:51:35 -0000
@@ -532,7 +532,7 @@
    site structures by category. */
   int result = 0; /* integer to be returned */
- double diff;
+ double diff = 0;
   switch((*(Site **)a)->cattype)
Brad Douglas <rez@touchofmadness.com>
On Thu, Mar 24, 2005 at 07:07:19AM -0800, Brad Douglas wrote:
On Thu, 2005-03-24 at 13:39 +0100, Markus Neteler wrote:
> Hi Brad,
> thanks for you patches. Please send them again to me as
> attachment(s) for easy CVS patching...
Here ya go!
Cool - patches applied!
