Attached is a cleanup of a few files in lib/ogsf. I have removed some
unused functions that shouldn't be necessary in trans.c. Let me know if
I have erroneously removed functions (is there a possibility of homebrew
modules calling these library functions?).
Brad Douglas <rez@touchofmadness.com>
(attachments)
ogsf.pat (6.72 KB)
Brad,
here
http://mpa.itc.it/markus/tmp/grass.cln
you find a clone analysis of GRASS 5 (done by Prof Antoniol from RCOST, Benevento,
Italy). It appears that
/ponza2/grass/src.contrib/GMSL/sg4d/trans.c P_pushmatrix 130 139
/ponza2/grass/src.contrib/GMSL/ogl3d_linux/gsf/trans.c P_pushmatrix 130 139
/ponza2/grass/src.contrib/GMSL/SG3d/trans.c P_pushmatrix 130 139
5623 5621
/ponza2/grass/src.contrib/GMSL/sg4d/trans.c P_popmatrix 145 154
/ponza2/grass/src.contrib/GMSL/ogl3d_linux/gsf/trans.c P_popmatrix 145 154
/ponza2/grass/src.contrib/GMSL/SG3d/trans.c P_popmatrix 145 154
6566 6565 6564
/ponza2/grass/src.contrib/GMSL/sg4d/trans.c P_rad_rotate 208 237
/ponza2/grass/src.contrib/GMSL/ogl3d_linux/gsf/trans.c P_rad_rotate 208 237
/ponza2/grass/src.contrib/GMSL/SG3d/trans.c P_rad_rotate 208 237
18877 18748
(and so forth)
seems to be a residual of the (unused) sg4d software which was used
before NVIZ was developed.
> Brad,
> here
Maybe I'm working too late, but I don't quite understand what the file
represents. If you could clarify, I would greatly appreciate it.
Sure: perhaps it's easiest to read this thread:
http://grass.itc.it/pipermail/grass5/2002-March/004674.html
In short:
"Prof. Antoniol was so kind to start a first try on
GRASS clone detection. A clone is considered as a piece of code
which is very similar to another piece of code (poor man's definition).
If a clone appears several times, it should become a library
function to simplify the maintenance."
The thread contains some further comments. If I recall correctly
the numbers tell the similarity between code pieces. Note that
code can be identical even if the text formatting is different.
Also in this case identical code in different code sections can
be considered as clone. From the indicated file above you can see
that according to software measures for example the P_... functions
appear at least twice in GRASS. From that, and knowing that s4gd
was the old visualization module in GRASS 4, I derived the posted
information that the P_..() functions were copied from s4gd to
ogsf while you already discovered that they are not used (any more).
Overall this seems to confirm that the indicated P_..() functions
are obsolete. We'll see if someone with homebrew software cries
in the next days, but it's rather unlikely in this case.
Hope this clarifies it a bit
