[GRASS5] PATCH: r.grow2
r.grow2 has not compiled for me for some time because abs() is
redefined. Attached is a fix. Any objections to me applying it?
Brad Douglas <rez@touchofmadness.com>
(attachments)
r.grow2.pat (1.02 KB)
Efficiency. The MAX() macro will result in one of the arguments being
evaluated twice, so its arguments shouldn't themselves be macros.
abs() is standard ANSI C (C89), so the local definition can be
removed. Then it doesn't matter about MAX() being a macro.
