Daniel Calvelo Aros wrote:
[Glynn]
> That's a bad idea, IMHO.
> Either developers will forget to commit them when lex.l or yac.y
> change, or they will end up being committed when lex.l or yac.y
> haven't changed (due to different lex/yacc programs generating subtly
> different code). Also, CVS doesn't deal with timestamps correctly, so
> there can be version skew issues.
Well, on the one hand, the files hadn't been touched since circa 2001.
"cvs log" says otherwise.
They were created on 2001/05/10, and have been each been modified
around 20 times between then and when I last modified them on
2004/09/09 (to add IS NULL/NOT NULL support).
Furthermore, even if lex.l/yac.y were never changed, the generated C
files (lex.yy.c, y.tab.c, y.tab.h) will typically differ between
developers, so "cvs commit lib/db/sqlp" would typically end up
committing the local copy.
> It would be better to just ensure that all lex/yacc files can be
> processed by any version of these tools. It shouldn't be that hard;
> we aren't doing anything particularly complex with lex/yacc.
On the other hand, having a "portable" input feels more correct. What needs to
be done in order to fix that? Linux, MacOSX (because of GNU, I believe) work
Ok. We spotted problems with solaris, and so far they are minor. Whitespace
is no issue. Let's just make solaris happy. Comments are more important, IMHO.
Paul, could you try moving the comments within the "C" part of the code?
Neither of those files is complex enough to need comments.
Try putting comments inside %{ and %}, but if that doesn't work, just
get rid of them.
