The subject says it all. d.what.vect and v.what were not in sync, d.what.vect
was correctly substracting the areas of the islands, when v.what was not.
On Sunday 31 August 2003 23:18, Thierry Laronde wrote:
Hello,
d.what.vect was correctly substracting the areas of the islands, when
v.what was not.
> Hello,
> v.what was not.
> The patch is simply derived from d.what.vect.
I have commited to cvs.
Should this go into the release_branch?
Yes, first someone should test the updated v.what in Lat/Long, UTM etc.
But keeping the bug in 5.0.3 I don't like too much...
> > Hello,
> > v.what was not.
Agreed.
For the tests, I think that G_begin_polygon_area_calculations() handles all
the conversions? [This is not humor, merely a question since I have only made
a quick comparison/search to fix this bug that was critical, at least for
what I was doing at the moment I'm only scratching the surface of GRASS
and there may be subtleties that I have missed].
+ inititalizations needed to do area calculations for
+ grid cells, based on the current window "projection" field.
+ G_begin_polygon_area_calculations();
