[GRASS5] pg.dll was not found
I have a problem when I try to create location from epsg. I get a
message as "This application has failed to start because pg.dll was not
found. Re-installing the application may fiz the problem"
I use windows XP and installed the software as told in page
http://geni.ath.cx/grass.html
Orkun ERSOY
Hacettepe University
Department of Geological Engineering
Beytepe-Ankara / TURKEY
06532
Ph: +90 312 2977700 / 126
not found. Re-installing the application may fiz the problem"
You will see in the screenshot of the cygwin installer (just before step
#6) that postgresql is selected for install. Make sure it is.
I guess either a dependancy in the grass package needs to be fixed or
the instructions have to state that more explicitly.
Hamish
Thanks Hamish,
I installed postgresql. When I try to reinstall, it is marked as "Keep",
I reinstalled it but I think there is an other simple problem.
regards
Orkun ERSOY
06532
-----Original Message-----
From: grass5-admin@grass.itc.it [mailto:grass5-admin@grass.itc.it] On
Behalf Of Hamish
Sent: Wednesday, December 21, 2005 12:22 AM
To: Orkun Ersoy
Cc: grass5@grass.itc.it
Subject: Re: [GRASS5] pg.dll was not found
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
