> I'm seeing something weird at the edges of images created with the
> PNG driver, maps aren't clipping to the edges correctly, looks like
> a bug...
> see
> http://bambi.otago.ac.nz/hamish/grass/png_bounds.html
> further details at the link.
OK, I've read that, but I'm still not sure what your problem is
exactly.
example 1:
Top row gets color from d.erase, but d.vect.area part is clipped.
Top right pixel is white.
Second-to-bottom row is the same as the top, including right-most pixel
being white. (examine with with xmag)
Bottom row is all white.
example 2:
(GRASS_HEIGHT slightly reduced)
Right most column is all white.
Bottom row is correct where d.vect.area has drawn, but white where
d.erase should have drawn. (middle)
Doing a xwd on a XDRIVER monitor of the same dimensions gives a nice
clean image without these artifacts.
> > a bug...
> > see
> exactly.
example 1:
example 2:
OK, I've fixed a couple of off-by-one errors in Polygon_abs() and
Box_abs(); let me know if any problems remain.
> > > the PNG driver, maps aren't clipping to the edges correctly,
> > > looks like a bug...
