[GRASS5] PNG-driver + monitorcap
Dear GRASS-Developers,
I am working with the PNG-driver for quite a while, but after a new
CVS-update the PNG-section in $GISBASE/monitorcap was missing and I
could not start the driver until I added the needed entry manually.
Did I do somithing wrong during update procedure?
If so, please let my know how can I correct it for the next time.
cheers
  stephan
Stephan Holl
GnuPG Key-ID: 11946A09
ICQ# 117277975
This appears to be a problem with the build procedure.
src/display/devices/PNGdriver/Gmakefile adds the appropriate
monitorcap entry if it doesn't already exist; however, it does this as
part of the rule for building the PNG driver itself. If
$(GISBASE)/driver/PNG doesn't need to be re-built, it won't update the
monitorcap file.
The way that src/display/devices/HTMLMAP/Gmakefile does it is correct.
