Michael Barton wrote:
Radim,
I went through your list, took out the commands that were in the menu and
have the following remainder. I've made a few notes. Could you take a minute
to look and see if you agree? Thanks.Michael
I don't know all, so I send cc to list.
----- revised list -----
d.ask - for programming
d.colorlist - mostly for programming but can add anyway
I don't think that this should be in menu. Colors should
appear in combo boxes. The option should be defined
with options = D_color_list().
BTW: default values dont work in GUI.
d.info - mostly for programming but will add anyway
I'am not sure that thsi should be in menu, we have enough
modules doing something useful, I think.
g3.region - obsolete (in g.region)
Not yet, and I am not sure if 'Set from a 3d raster map'
should be added to g.region, because of g3d dependency.
g.ask - for programming
g.filename - for programming
g.findfile - for programming
g.parser - for programming
g.tempfile - for programming
Yes.
r.average - obsolete (in r.statistics)
> r.median - obsolete (in r.statistics)
> r.mode - obsolete (in r.statistics)
No idea, but if it is osolete, it should be removed (from CVS).
r.in.arc - add (newly ported? I just forgot?)
r.watershed - add (newly ported?)
Probably.
tcltkgrass - obsolete (replaced by GIS manager)
So it can be removed?
v.in.dwg - not in default compile
Yes, but it could be conditional.
v.kcv - add (newly ported?)
v.mkgrid - add (newly ported?)
Yes.
v.neighbors - add
v.out.dxf - add (recently updated)
Yes.
WHAT ARE THESE??
poly_to_bmif -
bmif_to_cell -
No idea.
Radim
