Dear developers,
while working with v.to.db I ran into the following problem.
Added a column to the existing attribute-table (dbf)
echo "CREATE TABLE ${MYAREA} ( id int, cat varchar(50), \
area double precision);"|db.execute
tryed to load area-features into the table:
v.to.db map=${MYAREA} option=area units=meters column=area
but: it fails.
when I update the newly created columns with 0-values before, I can
upload the area-attributes to each dataset.
echo "UPDATE ${MYAREA} SET area=0 WHERE id >= 1;"|db.execute
Is that the correct way? If so, a hint on the manual-page would be good.
THanks
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
