Dear Pretesters,
time has come to publish beta11...
http://www.geog.uni-hannover.de/grass/grass5/source/
I would like to ask you to test this tarball.
For Linux I will put out a binary tarball later this day.
NOTE:
The LZW-compression is removed from GRASS floating point
raster maps and G3D maps. Means: You have to convert
*all* FP and G3D maps. Plain CELL (Integer) maps are not affected.
See announcement and link to conversion tool here:
http://www.geog.uni-hannover.de/grass/announces/announce_lzw_removal.html
The conversion tool r.lzw2z runs pretty well now.
Thanks in advance for testing the new package,
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
subject 'unsubscribe grass5'
Hallo Markus,
danke fĂĽr die Arbeit:
Bitte mach die Warnung in dem ftp Verzeichniss deutlicher!
Wolltest Du nicht nur sourcen rausgeben, damit sich nur wirklich die
Entwickler dran beteiligen?
Bernhard
NOTE:
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
I am sorry, I have hit the wrong button sending this to the list.
(That's why it is in German. Here is a rough translation.)
Hello Markus,
thanks for the hard work.
Please make the Warning in the ftp directory more visable.
Didn't you plan to only release a source tarball, so that
only developer can really pretest?
On Thu, Jan 25, 2001 at 02:09:23PM +0100, Bernhard Reiter wrote:
Hallo Markus,
Bernhard
> NOTE:
> Markus
Hello Markus,
O.k., I will delay the binaries as requested.
But the binaries should be tested as well, therefore I was thinking
to publish the as "beta11pre1".
> Hallo Markus,
> Bernhard
> > Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
> > NOTE:
> > Markus
As we do expect minor configuration bugs in the beta11pre1 release,
the binaries will change anyway. There is no point in releasing
them, because the target audience should be able to produce binaries
anyway.
Bernhard
After Markus Neteler all ready solved one of my problems I came up with in the
beta11pre1 here is one more:
GRASS compiled and installed fine, but running d.vect from tcltk
(Display->Vector->display vector map) results in a "zombi" that I have to
kill before the tcltk interface can be stopped. Here the result of ps ax:
4870 pts/3 S 0:00 sh ./grass5
4873 pts/3 S 0:00 sh /opt/grassb11p1//grass5/etc/Init.sh
4886 pts/3 S 0:00 wish /opt/grassb11p1//grass5/bin/tcltkgrass
4901 ? R 1:10 x0 /opt/grassb11p1//grass5/dev/fifo.1a
/opt/grassb11p1//grass5/dev/fifo.1b
I hope someone understands this. If you need further info I will try to answer.
By the way, the vector I used for testing works fine in the CVS dating
08/01/2001...
Thanks everyone,
Arne
Arne Pallentin
Department of Earth Sciences
The University of Waikato
Private Bag 3105
Hamilton - New Zealand
Ph.: +64-7-838 4024 ext. 6229
Home: +64-7-856 7877
Fax. +64-7-856 0115
e-mail: arne@waikato.ac.nz
On Sat, Jan 27, 2001 at 12:34:39PM +1300, Arne Pallentin wrote:
08/01/2001...
Where's the zombie? I see three sleeping processes (S) and one runnable
(R). Are you referrering to the "?" for x0? That just means it doesn't
have a controlling terminal. The GRASS monitors are kind of funky, but
if you select Display->Monitors->Stop->x[0-6] or "All", it will signal
x[n] to shut down. TclTkGrass also has an option to stop all monitors
at shutdown (good to just leave always "checked").
Eric G. Miller <egm2@jps.net>
