Hi Helena:
both ways returned the "wait_ok" error.
andy
On Thursday, October 25, 2001, at 11:29 AM, Helena wrote:
andy
try nviz -q
it will open nviz and then go to panels->surfaces and load new surface to see
whether it will work.
you can also try to type nviz elevation.dem, but it should have worked the
way you did it -
it loks like a bug.Helena
agena wrote:
hi again:
jeshua zapped me libdl.a and libdl.dylib, so i have them installed now.
however, if i try nviz from tcltkgrass, the command passed is "nviz
el=elevation.dem", which gives "Sorry, <el=> is ambiguous".if i try from the cli, i get : "ERROR: window name "wait_ok" already
exists in parent..."any ideas?
thanks,
andyOn Thursday, October 25, 2001, at 10:29 AM, Glynn Clements wrote:
andy agena wrote:
i have grass5pre2 running on darwin1.4 (osx 10.1) and received the
following error when trying to launch nviz. most of my *.dylib are in
/usr/lib; i only have a few tcltk *.dylib's in /usr/local/lib.GRASS 5.0.0pre2 > nviz
dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library:
/usr/local/lib/libdl.dylib (No such file or directory, errno = 2)Odd. Is libdl.dylib present on your system, in /usr/lib,
/usr/local/lib or elsewhere?FWIW, try removing $(DLLIB) from src.contrib/GMSL/NVIZ2.2/src/Gmakefile;
if Tcl needs libdl, configure will add -ldl to TCLTKLIBS.--
Glynn Clements <glynn.clements@virgin.net>_______________________________________________
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
