andy agena wrote:
nviz -q (with or without tcltkgrass running) very briefly flashes the
"wait_ok" and nviz boxes, then gives the '"wait_ok" already exists in
parent' error in the xterm. the nviz i/o box doesn't appear.
using the tcltkgrass menu for nviz pops up three windows (wait_ok, nviz
i/o, and nviz), nviz i/o says: 'loading data,' 'update elev null
mask,' 'loading data,' 'translating colors,' then ends with 'sorry,
<el=> is ambiguous' (this "el=" is passed from the command line box in
the nviz dialog and i can't edit it).
I've found something which looks relevant.
In NVIZ_AppInit (nvizAppInit.c), Ninit() may be called twice. First:
if (Tk_Init(interp) == TCL_ERROR) {
/* Handle TCL/TK errors by passing to the G_parser
** Calls Ninit to spit out NVIZ usage message
** instead of TCL usage message
Ninit(interp, mainWindow);
return TCL_ERROR;
then later:
return TCL_OK;
Ninit() calls Ninitdata(), which calls parse_command(), which:
1. Creates all of the options with G_define_option() then calls
G_parser(), hence the "ambigous" error (the second run will define all
of the options again, so the "el=..." argument will match both of the
"elevation" options).
2. Creates the .wait_ok window with:
if (Tcl_Eval(interp, startup_script) != TCL_OK) {
where startup_script is:
char startup_script =
"toplevel .wait_ok\n\
label .wait_ok.wait -text \"Please wait...\" -fg red -bg black\n\
pack .wait_ok.wait -ipadx 20 -ipady 20 -expand 1 -fill both\n\
wm geometry .wait_ok \"+800+50\"\n\
wm geometry . \"+100+100\"\n\
update\n\
grab .wait_ok.wait";
In short, the symptoms which you describe are exactly what I would
expect to happen if Ninit() was called twice.
Try changing the first block of code above to e.g.:
fprintf(stderr, "Tk_Init failed\n");
return TCL_ERROR;
