hello all:
i have grass5pre2 running on darwin1.4 (osx 10.1) and received the following error when trying to launch nviz. most of my *.dylib are in /usr/lib; i only have a few tcltk *.dylib's in /usr/local/lib.
any help is appreciated.
thanks,
andy
p.s. please cc me in any responses as i'm using the digest mode for the grass5 list.
p.p.s. when is baylor going to offer a digest for the grasslist?
---error---
GRASS 5.0.0pre2 > nviz
dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library: /usr/local/lib/libdl.dylib (No such file or directory, errno = 2)
child process exited abnormally
while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/usr/local/grass5/bin/nviz" line 13)
Odd. Is libdl.dylib present on your system, in /usr/lib,
/usr/local/lib or elsewhere?
FWIW, try removing $(DLLIB) from src.contrib/GMSL/NVIZ2.2/src/Gmakefile;
if Tcl needs libdl, configure will add -ldl to TCLTKLIBS.
Hi Andy,
I am sorry I missed the part about the missing "/usr/local/lib/libdl.dylib", that would be my fault.
I will tar up the lib and send it to you right away.
Kind regards,
Jeshua Lacock http://OpenOSX.com
Programmer/Owner http://SierraMaps.com
Phone: (760) 935-4736 http://3dTopoMaps.com
hi again:
jeshua zapped me libdl.a and libdl.dylib, so i have them installed now.
however, if i try nviz from tcltkgrass, the command passed is "nviz el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
if i try from the cli, i get : "ERROR: window name "wait_ok" already exists in parent..."
any ideas?
thanks,
andy
Odd; that works fine here, both from the command line and via
tcltkgrass.
What does "nviz help" say?
tcltkgrass.
GRASS 5.0.0pre2 > nviz help
Description:
nviz - Visualization and animation tool for GRASS data
Usage:
nviz2.2_script [-qkx] [elevation=name[,name,...]]
[vector=name[,name,...]] [sites=name[,name,...]] [path=name]
[script=name]
Flags:
-q Quickstart - Do not load any data
-k Script kill option
-x Start in Demo mode
Parameters:
elevation Raster file(s) for Elevation
vector Vector overlay file(s)
sites Sites overlay file(s)
path Set alternative panel path
script Execute script file at startup
Mapset <PERMANENT> in Location <spearfish>
> tcltkgrass.
[snip]
That implies that the error message is bogus, i.e. a problem with
G_parser(), but I can't see anything obvious.
> > tcltkgrass.
[snip]
I am guessing here, but is it possible that TCL (tcltkgrass) is getting
confused with the command? In other words is it reporting the error
before it even gets to G_parser?
It might help to know what the raster file name is that is creating the
problem in case of odd characters. Or is it "elevation.dem".
Bob Covill
Tekmap Consulting
E-Mail: bcovill@tekmap.ns.ca
hi glynn:
this is the console output i get when i fire up xwindows (i've snipped the piece about 'if your version is old..'). do you think any of this is relevant to my problems?
thanks,
andy
Warning: no access to tty (Inappropriate ioctl for device).
Thus no job control in this shell.
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
/usr/X11R6/lib/X11/xinit/xinitrc: command not found: fspanel [30]
tcltkgrass.
[snip]
> > > tcltkgrass.
> [snip]
it gives him the same error even if he just calls nviz -q, so it is not in
the name,
if I understand it correctly. Andy, does it open any of the windows when you
start nviz -q
(the graphics window, "please wait" window and then the tcltk interface)?
Helena
Bob Covill
Tekmap Consulting
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
> > > tcltkgrass.
> [snip]
Unlikely; the error message matches the one in src/libes/gis/parser.c:
if (got_one > 1)
fprintf(stderr,"Sorry, <%s=> is ambiguous\n", the_key) ;
return(1) ;
This error message should only occur if one of the argument names (the
LHS of an "arg=val" argument) is a prefix of multiple declared
options, but isn't an exact match for any of them.
I can't see how any of these could cause the error message in
question.
