X11 support: yes
DBM support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
but I have this error:
gcc -g -Wall -Wall -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/dist.i686-pc-linux-gnu/include
-I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
-I/usr/local/pgsql/include/ -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
-o OBJ.i686-pc-linux-gnu/open_ogr.o -c open_ogr.c
cc1: warning: changing search order for system directory "/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory
cc1: warning: changing search order for system directory "/usr/include"
open_ogr.c: In function `V1_open_old_ogr':
open_ogr.c:37: structure has no member named `ogr'
open_ogr.c:44: structure has no member named `ogr'
open_ogr.c: At top level:
/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include/gis.h:36: warning:
`GRASS_copyright' defined but not used
make[3]: *** [OBJ.i686-pc-linux-gnu/open_ogr.o] Error 1
make[3]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector/Vlib'
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib'
make: *** [default] Error 1
I think there is a problem with #define HAVE_OGR...
Could someone help me?
Thank you
Mauro
________________________________________
Hai bisogno di una pausa? Vieni a giocare su Jumpy! http://giochi.jumpy.it
X11 support: yes
DBM support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
MySQL support: no
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
GLw support: no
NLS support: no
Maybe the
top_dir/include/config.h
is not updated and you have to add: #define HAVE_OGR 1
X11 support: yes
DBM support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
GD support: yes
Tcl/Tk support: yes
MySQL support: no
ODBC support: yes
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
GLw support: no
NLS support: no
gcc -g -Wall -Wall
nclude -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/include
nclude -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include
-I/usr/include -I/usr/local/pgsql/include/
nclude \
"/usr/local/include" cc1: warning: as it has already been specified as a
non-system directory cc1: warning: changing search order for system
directory "/usr/include" cc1: warning: as it has already been specified as
a non-system directory open_ogr.c: In function `V1_open_old_ogr':
`/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector/Vlib' make[2]:
`/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib/vector' make[1]: ***
[subdirs] Error 1
`/home/rpms/GRASS/Sept2002/grass51_exp_2003_02_08/lib' make: *** [default]
Error 1
Thank you
Mauro
Sorry, I forgot some #ifdef HAVE_OGR, must be in all *_ogr.c,
+ there were some bugs in read.c, rewind.c for compilation without
OGR. Everything is fixed now in CVS. If you want to compile with
OGR, try to configure with
--with-gdal=/your_path_to/gdal-config
