[GRASS5] Problem converting NAD27 to NAD83.
Hello, I am having problems with v.proj (and r.proj) when projecting vectors from a NAD27 database to NAD83 use GRASS 6.0
This is the output from the v.proj command:
Input Projection Parameters: +proj=utm +zone=10 +a=6378206.4 +rf=294.9786982 +no_defs +nadgrids=ntv1_can.dat
Input Unit Factor: 1
Output Projection Parameters: +proj=utm +zone=10 +a=6378137 +rf=298.257222101 +no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
WARNING: The vector 'lines' already exists and will be
          overwritten.
Creating vector file...
pj_transform() failed
cause: failed to load NAD27-83 correction file
Error in pj_do_transform
This is my PROJ_INFO file:
datum: nad83
dx: 0.000000
dy: 0.000000
dz: 0.000000
proj: utm
ellps: grs80
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572221010
zone: 10
This is my DEFAULT_WIND file:
proj: 1
zone: 10
north: 6665000
south: 5300000
east: 696621
west: 332705
cols: 72783
rows: 273000
e-w resol: 5.00001374
n-s resol: 5
Any suggestions?
Craig Funk
funkmeister -at- lynxseismicdata -dot- com
Hello Craig
        overwritten.
The most common cause for that error is that the points you are trying to re-project fall outside the area covered by the datum shift grid file (ntv1_can.dat). Are you sure it is the correct file for your area (Canada).
If you are having trouble with the grid shift files you could try doing a less precise datum transformation using a 3 or 7-parameter transformation. Re-run g.setproj in the NAD27 location to set up your datum parameters.
Paul
datum: nad83
dx: 0.000000
dy: 0.000000
dz: 0.000000
proj: utm
ellps: grs80
es: 0.0066943800
f: 298.2572221010
zone: 10
proj: 1
zone: 10
north: 6665000
south: 5300000
east: 696621
west: 332705
cols: 72783
rows: 273000
n-s resol: 5
Any suggestions?
Craig Funk
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Paul
Thanks Paul,
It ends up that the ntv1_can.dat file did not appear to be installed properly. Where should the file live? I placed it in etc/nad directory of the GRASS installation and then the r.proj and v.proj commands worked fine.
I built my GRASS install from source on a Mac G5. Is this maybe a problem with the makefiles?
Craig
> (Canada).
> datum parameters.
> Paul
Thanks Paul,
worked fine.
Did you build GDAL with --with-static-proj4? This option is not
compatible with GRASS.
Brad Douglas <rez@touchofmadness.com>
No, it is not compiled with that option.
Craig
worked fine.
That file should be installed into etc/nad by lib/proj/Makefile. Check
the output from "make -C lib/proj" in case there is an error which
prevents it from being installed.
