[GRASS5] problem in Grass 5.3
I've been using Grass 5.3 for a couple weeks now on a Mac OSX/BSD G4 and overall it has been extremely stable. Last night, I ran into the first bug so far. I needed to georeference a set of points representing cesium magnetometry data from an archaeological site. To do this, I converted the site file to a vector point file, and the vector point file to an ascii vector point file. So far so good.
However, when I tried to use v.transform I ran into problems. First, the documentation describes this as a module to transform binary vector files, but the TCLTK interface wants ascii vector files. The command line interface also seems to want ascii files. In the TCL interface at least v.transform only looks for files in the dig.ascii folder (correct for ascii files of course), but won't find them unless they are copied into the dig folder (i.e., binary vector files).
Second, when I ran it with 9 points for coordinate transformation, it crashed with a maloc and out of memory error. I reduced it to 4 points and it ran.
Finally, it produced the header of an ascii file output (in the dig folder) but not the rest of the file. It DID produce a file of transformed coordinates in the dig.att folder.
  I had to use this attribute file to paste into an excel spreadsheet, along with the magnetometry values from the sites file, which I then exported to CVS and imported into s.in.ascii.
A very roundabout method. Anyway, v.transform seems to be confused about what kind of files it is using for input and output.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
