[GRASS5] Problem with d.mon under grass5.4
I installed grass 5.4 with options without: postgres,mysql,odbc,fftw,proj,gdal,opengl,tiff,tcltk,png
because I thought it was quicker for me and I did not need them.
Unfortunately, when I type
   d.mon start=x0
I have the following error message:
Could not execute monitor: No such file or directory
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
If anyone can help me to understand which options should I include to recompile grass correctly and let me understand if there is a way to compile only the missing libraries, I will appreciate.
Thank you in advance,
Damiano Triglione
damiano.triglione@polimi.it
postgres,mysql,odbc,fftw,proj,gdal,opengl,tiff,tcltk,png because I
   d.mon start=x0
It isn't necessarily related to configure options. If you look in the
error.log it will probably indicate that there was an error in
src/display/devices/XDRIVER. You will need to examine the output from
"make" to determine the actual error.
