Hi
at least tested to work on one server
grasslinks-reimplemented prog called 'webgrass'
You may wish to try that one on:
http://tigers.ru/webgrass_e/index.html
and take the source at
http://tigers.ru/webgrass_e.tar.gz
Hint: check write permissions for the apache user ( often it is 'nobody') for the tmp directory where
temporary files are stored.
Good luck
--alex
--- Anand Mohan <anand@mail.arkinsys.com> wrote:
hi
Iam working with grass and grasslinks. I am not
able to display the selected map in the browser.In
create_gif subroutine gif is creating under tmp file
with out any data in the file.can any body help me
in this regard what may be the problem.I observed
that paint.ppm file is not there under home
directory.is it create dynamically.please help me in
this regard.Thanks & Regards
Anand Mohan G
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
