[GRASS5] Problem with sockets on Linux
I've just updated my CVS (this afternoon at 16:00), run again configure
make and make install... when I try to start x0, (d.mon start=x0) I get
"no socket to connect to for monitor <x0>". What's wrong?
Bye
PS: on the same machine, but of course in a different folder, I have
GRASSb11, and it's working (it wasn't compiled with socket support).
subject 'unsubscribe grass5'
Hi Andrea
configure make and make install... when I try to start x0, (d.mon
start=x0) I get "no socket to connect to for monitor <x0>". What's
wrong?
You may have already done this but try
make distclean
configure
make
make install
If your previously compiled version was not with sockets enabled, then
some of the d.* commands need to be re-compiled. That means the object
files need to be removed.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I've tried make distclean, but without success, I always get the
same error. Before "make distclean" I also deleted my installation
directory and my .grassrc5. Please note that I install with a different
prefix (that should not make any difference, but I don't understand
where the error is). Any other ideas? Some way to get more detailed
error logs?
Bye
Justin Hickey wrote:
Hi Andrea
> wrong?
make distclean
configure
make
make install
Hope this helps.
Sincerely,
Bangkok, Thailand
Hi Andrea
different prefix (that should not make any difference, but I don't
understand where the error is). Any other ideas? Some way to get more
detailed error logs?
Unfortunately, I don't have any other ideas, and our developer in charge
of the socket code (Eric Miller) is currently having ISP problems that
delay his sent mail by up to 24 hours. Hopefully a response from him is
on the way.
Sorry I couldn't offer more help.
Sincerely,
Bangkok, Thailand
error logs?
Bye
To confirm: The same problem occurs on SUN/Solaris. No effect with
make distclean and a complete re-compile (I tried twice). There must
be a recent bug... (another reason to clean out the unused driver stuff).
Regards
> Hi Andrea
> > wrong?
> make distclean
> configure
> make
> make install
> Hope this helps.
> Sincerely,
> Bangkok, Thailand
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
> error logs?
> Bye
> Andrea
Is the server running (or did it exit)? (try "ps aux | grep <driver>").
Does following with a "d.mon select=<DRIVER>" succeed? (the timing
issue...).
Eric G. Miller <egm2@jps.net>
No, the server is not running, I can't find any new process (I don't
know the driver name (is it simply "xo"?), but if you sort processes
by PID you see if something has been created after grass start).
The following "d.mon select=x0" of course does not work and returns
the same error.
Hope this helps
PS: which server ports are used by the X driver? Maybe it finds them
occupied by another application (I use 4444/6001/7001 for an in-house
application...). Anyway, I think that server ports numbers should be
configurable...
> > error logs?
> > Bye
> > Andrea
issue...).
the same error.
Hope this helps
I think the problem is d.mon isn't getting built properly for some
reason. I change the arguments for "start" if the USE_G_SOCKS symbol
is defined. I think the drivers are being called with all the fifo
args, so they are exiting (do you get a "Usage" message?).
configurable...
No ports are used. Just local UNIX socket files. I figured UNIX
sockets are simpler and there'd be no reason another user should ever
"connect" to a display driver started by someone else. Also, UNIX
sockets should be faster since the kernel has to do less work (mearly
queues up data in a buffer from write() and pops the data to the
application on read()). Socket files currently live in
<mapset>/.tmp/<host>/<driver_name>
I've updated my files to last CVS, and now driver is working well.
Thanks
> the same error.
> Hope this helps
> Andrea
> configurable...
Thanks
Very good...
Eric,
are you planning to check in your new code for $HOME/.grass5/com/
? Then we could get rid of the "locks" directory. Or are there
objections?
Regards
On Mon, Mar 12, 2001 at 04:55:15PM +0000, Markus Neteler wrote:
Eric,
objections?
The "locks" directory is needed for the FIFO/IPC drivers. So, as long
as we are keeping those, we will need the "locks" directory. The
sockets code uses a different mechanism, so it doesn't matter if we have
the $HOME/.grass5/com stuff. When I last mentioned the code I'd worked
up for the $HOME/.grass5, there wasn't much consensus on it. I assumed
we didn't want to add this change at this time. I can still check in
the code file, but I guessed it was going to be a 5.1 thing (if we want
to do it).
One good reason to have the $HOME/.grass5, would be to move the socket
file out of the mapset (though, two users shouldn't be able to
simulataneously have their current mapset be the same -- or am I
mistaken?).
FYI: The sockets "lock" equivalent works like:
1) User starts a server with "d.mon".
2) Server checks if the socket file it plans to use already exists.
   a) If the file exists, server tries to make a connection (see if
      anything is "listening").
      i. If the connection is successful, the server exits with an
          error message.
      ii. If the connection is unsuccessful, the server removes the
          file.
3) Server then calls G_sock_bind() on the file name (which will create
    the file anew, but associate with the server process). Later (after
    the fork()), server calls G_sock_listen() on the file descriptor to
    begin accepting connections.
The above isn't a perfect test, but should do the right thing most of
the time. I suppose it could be possible for a driver to be running
and be busy processing another client request, such that the connection
attempt by the new server process will timeout. In that scenario, the
socket file will get "hijacked" by the new server process. It would
take some effort by the user to make this happen though. The user would
have to have a long running process tieing up the connection to a server
(say "x0"), then run "d.mon x0" to start x0 again all the while another
module is keeping the original "x0" busy.
