Hallo!
I'm trying to build a RPM for grass5 which can be build as a normal
user not as root. I know that this is possible because I tried it on
the command shell. But using the specfile I have the problem that
the make-process stops with:
GRASS GIS source code compiled successfully.
* Check file error.log for modules not been compiled due to error.
* Install GRASS with (possibly as root)
make install
and waits for a return. (typing make in the bash the make-process
stops correctly with a new prompt)
Neither
* echo ";" | make
nor
* echo -e "\rn" | make
worked.
Has somebody any idea what's going wrong?
Thanks in advance
Silke
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
