I just tried use i.in.erdas to read in a multiband *.lan file of LandsatTM images. It didn't work and produced the error listed below. With i.in.erdas out of commission, there seems to be no way to get multiband images into GRASS. I tried r.in.gdal (I have 1.1.9 installed) and it wouldn't read *.lan images or geotiffs in multiband format. Any suggestions?
I am using GRASS 5.3 (12 January 04 build) on a Mac OSX 10.2.8 system. The *.lan file is a version 7.4 format file of 7 Landsat TM bands, with a size of 375 Mb. Note below that it does recognize the file and read the header correctly.
- - - i.in.erdas error - - -
Swapping Enabled
HEAD74
pack type ------------- 0 == 8 bit/pixel
number bands----------- 7
number cols,rows------- 7768, 7225
starting coordinate --- 1, 1
map type (int, float) - 1
number classes -------- 0
unit-type: ------------ N (N=None A=Acre H=Hectare O=Other)
area per pixel -------- 1.000000
map coordinate -------- 67089.500000, 4414792.500000
pixel size ------------ 28.500000, 28.500000
UTM coordinates used remember that the UTM zone is unknown
and must be set using the grass support function on the header file.
WARNING: G_set_fp_type() can only be called with FCELL_TYPE or DCELL_TYPE
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
