a colleague of mine from Argentina is facing problems
to import LANDSAT data in UTM.
Displaying a map leads to:
GRASS 5.7.cvs > d.rast markus.1
WARNING: [markus.1] in mapset [beinlich] - in different zone [20] than
current region [-20]
WARNING: unable to open raster map [markus.1 in beinlich]
ERROR: Not able to open cellfile for [markus.1]
The location is defined as (UTM, southern hemisphere):
GRASS 5.7.cvs > cat WIND
proj: 1
zone: -20
north: 6422700
south: 6285990
east: 5509920
west: 5368500
cols: 4714
rows: 4557
e-w resol: 30
n-s resol: 30
Mapset <beinlich> in Location <rosarioutm>
Looking at the map header:
GRASS 5.7.cvs > cd cellhd/
GRASS 5.7.cvs > cat markus.1
proj: 1
zone: 20 <-- shouldn't this be -20?
north: 6362801.5
south: 6341626
east: 726550.5
west: 703978.5
cols: 792
rows: 743
e-w resol: 28.5
n-s resol: 28.5
format: 0
compressed: 1
GRASS 5.7.cvs > g.proj -p
-PROJ_INFO-------------------------------------------------
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : utm
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
zone : 20 <- positive, but
south : defined <- southern hemisphere indication
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
GRASS 5.7.cvs > g.proj -w
PROJCS["UTM Zone 20, Southern Hemisphere",
GEOGCS["wgs84",
DATUM["WGS_1984",
SPHEROID["wgs84",6378137,298.257223563],
TOWGS84[0.000,0.000,0.000]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-63],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["meter",1]]
May it be possible that G_get_projinfo() doesn't understand
well that 'south' is defined?
Mhh, probably I have to debug a bit.
