[GRASS5] Problems with v.external
Hi at all,
I've some problem with v.external command.
*** I've PostGIS DB table "comuni"
riade=# \d comuni
              Table "public.comuni"
    Column | Type | Modifiers
  gid | integer | not null
  nome_com | character varying(70) |
  area | double precision |
  perimeter | double precision |
  cod_amm | character varying(9) |
  cod_reg | character varying(2) |
  cod_pro | character varying(3) |
  cod_com | character varying(3) |
  cod_procom | character varying(6) |
  grado_mont | character varying(14) |
  zonaalt | integer |
  ripartizio | integer |
  qtmedia | integer |
  qtminima | integer |
  qtmassima | integer |
  regione | character varying(21) |
  provincia | character varying(20) |
  the_geom | geometry |
Indexes:
     "comuni_pkey" primary key, btree (gid)
Check constraints:
     "$2" CHECK (geometrytype(the_geom) = 'POLYGON'::text OR the_geom IS NULL)
     "$1" CHECK (srid(the_geom) = 23032)
*** imported in GRASS using command:
v.external dsn="PG:host=localhost user=postgres dbname=riade" layer=comuni output=comuni
Building topology ...
Feature: 8102
Topology was built.
Number of nodes : 15678
Number of primitives: 16211
Number of points : 0
Number of lines : 0
Number of boundaries: 8109
Number of centroids : 8102
Number of areas : 8109
Number of isles : 8109
Number of areas without centroid : 7
*** DB Connection status is:
v.db.connect -p map=comuni
Vector map <comuni> is connected by:
field <1> table <comuni> in database <PG:host=localhost user=postgres dbname=riade> through driver <ogr> with key <FID>
*** But showing this data with d.vect I've this error:
D3/4: rtree_read_branch()
D2/4: Vect_cidx_open(): name = comuni mapset= riade_query_prova3
D2/4: dig_cidx_init()
D3/4: dig_read_cidx()
D3/4: Cidx header: file version 5.0 , supported from GRASS version 5.0
D3/4: byte order 0
D3/4: header size 9
D3/4: V2_open_old_ogr()
D3/4: header size 9
D3/4: 16218 records read from fidx
D2/4: V1_open_old_ogr(): dsn = PG:host=localhost user=postgres dbname=riade layer = comuni
D2/4: 15 layers found in data source
D2/4: OGR layer 14 opened
D1/4: Vect_open_old(): vector opened on level 2
D1/4: Vect_read_dblinks(): map = comuni, mapset = riade_query_prova3
D3/4: Vect_check_dblink: field 1
D1/4: Vect_Rewind(): name = comuni
D2/4: V2_rewind_ogr(): name = comuni
D3/4: G_str_to_color(): str = 'red'
D3/4: G_str_to_color(): str = 'none'
D1/4: overlap = 1.000000
D1/4: display areas:
D2/4: n_areas = 8109
D3/4: area = 1
D3/4: display area 1
D3/4: Vect_get_area_points(): area = 1
D3/4: n_lines = 1
D3/4: append line(0) = 1
D3/4: Vect_read_line()
D4/4: V2_read_line_ogr() line = 1
D4/4: FID = 0
D4/4: Read feature (FID = 0) to cache.
ERROR: Cannot read feature, FID = 0 <<<<--------------******
*** gid (first field) in table conuni has gid=[0-8101] so 0 exist as Feature ID (FID?)
*** Differently Table Comuni could be shown suing DB link in qgis.
step missing?
Thanks for your help.
Luigi Pirelli
www.riade.net
www.acsys.it
