From a Mandrake developer I received the attached
patches (5.0.3/5.3, 5.7).
Can I apply them?
(attachments)
grass-5.0.3-configure-freetype-fix.patch (350 Bytes)
grass-57-freetype-includes-fix.patch (682 Bytes)
Can I apply them?
patches (5.0.3/5.3, 5.7).Can I apply them?
-LOC_CHECK_INCLUDES(freetype/freetype.h,FreeType,$FTINC)
+LOC_CHECK_INCLUDES(ft2build.h,FreeType,$FTINC)
We changed from checking ft2build.h in 5.0.0 to freetype/freetype.h in
5.0.1, and we presumably did so for a reason.
Unless someone beats me to it, I'll try to find the commit message and
any emails relating to the change.
(cc Buchan)
> Can I apply them?> -LOC_CHECK_INCLUDES(freetype/freetype.h,FreeType,$FTINC)
> +LOC_CHECK_INCLUDES(ft2build.h,FreeType,$FTINC)We changed from checking ft2build.h in 5.0.0 to freetype/freetype.h in
5.0.1, and we presumably did so for a reason.Unless someone beats me to it, I'll try to find the commit message and
any emails relating to the change.--
OK, here is the commit log:
http://grass.itc.it/pipermail/grass-commit/2002-September/006605.html
So it should be somewhere here:
http://grass.itc.it/pipermail/grass5/2002-September/author.html#start
> > Can I apply them?
> any emails relating to the change.OK, here is the commit log:
Nope; it turns out to have been a private email (from you):
To: Glynn Clements <glynn.clements@virgin.net>
Subject: Question on configure
Date: Tue, 24 Sep 2002 15:01:12 +0200
Message-ID: <20020924150112.G25861@itc.it>
to get configure accepting the freetype lib (Redhat 7.1)
I had to change:cvs diff configure
Index: configureRCS file: /grassrepository/grass/configure,v
retrieving revision 1.117
diff -r1.117 configure
10489c10489
< for ac_hdr in ft2build.h
> for ac_hdr in ./freetype/config/ftbuild.has ft2build.h does not exist on Redhat 7.1:
locate /freetype/config/ftbuild.h
/usr/include/freetype2/freetype/config/ftbuild.hMay I ask you to modify the configure[.in] if possible?
Currently, d.text.freetype/main.c does:
#include <freetype/freetype.h>
So, that's what configure should be checking for. If the source code
was changed to include ft2build.h (and use the macros for including
the other headers), then changing the configure checks would make
sense.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
|>>>Can I apply them?
|>From: Markus Neteler <neteler@itc.it>
|>I had to change:
|>cvs diff configure
|>Index: configure
|>10489c10489
| sense.
I sent Markus two patches, one for grass-5.{0,3}, which just change the
configure.in, the one for grass-5.7 added an #include ft2build.h (but it
was incomplete, it needs to use the macro to get the freetype header).
The problem is that with freetype-2.1.8 and later, freetype.h now has:
#ifndef FT_FREETYPE_H
#error "`ft2build.h' hasn't been included yet!"
#error "Please always use macros to include FreeType header files."
#error "Example:"
#error " #include <ft2build.h>"
#error " #include FT_FREETYPE_H"
#endif
So, configure in grass-5.{0,3} fails, even though nothing seems to
include the header, and compilation fails (if configure succeeded) in
d.text.freetype.
Buchan
Buchan Milne Senior Support Technician
Obsidian Systems http://www.obsidian.co.za
B.Eng RHCE (803004789010797)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFA1+tNrJK6UGDSBKcRAoXyAKCj65WwwBDWhP/mEFD9eAlVQsDBjgCbBy2K
7cLNl+TZkW4IqZvTWQi7tSw=
=fiQp
-----END PGP SIGNATURE-----
> > > Can I apply them?
> http://grass.itc.it/pipermail/grass5/2002-September/author.html#startNope; it turns out to have been a private email (from you):
> Message-ID: <20020924150112.G25861@itc.it>> to get configure accepting the freetype lib (Redhat 7.1)
> I had to change:
> cvs diff configure
> Index: configure
> 10489c10489
> May I ask you to modify the configure[.in] if possible?Currently, d.text.freetype/main.c does:
sense.
Yesterday I have updated thei mentioned RH7 box to:
rpm -ql freetype-devel-2.0.9-2 | grep ft2build.h
/usr/include/ft2build.h
Yes, the source code is proposed to be changed.
|>>>Can I apply them?
|>I had to change:
|>cvs diff configure
|>Index: configure
|>10489c10489
| sense.
was incomplete, it needs to use the macro to get the freetype header).The problem is that with freetype-2.1.8 and later, freetype.h now has:
#error "Example:"
#endifSo, configure in grass-5.{0,3} fails, even though nothing seems to
d.text.freetype.
I have applied the patches to 5.3-CVS and 5.7-CVS.
