[GRASS5] ps.map and -fwritable-strings
I wanted to fix writable-strings in ps.map. I walked through source
and found 8 pointers to string constants but program never writes into
these strings.
Does anybody know where writable-strings should be, how was discovered
that problem is in writable-strings, how to simulate problems or why should be
problem on Linux only?
Radim
subject 'unsubscribe grass5'
On Sat, Nov 04, 2000 at 10:48:21AM +0100, Radim Blazek wrote:
these strings.
Hi Radim,
this was reported for Linux only since years. If the flag was missing,
no vector support would be there... (I never tried myself, just
collected reports).
This is all I know. It seems to be still existing as I built beta4 (or so)
without this flag set and had to re-publish the linux binaries with
ps.map properly compiled after receiving complaints.
Regards
as Eric reported that the ps.map Vector-problems seems to
be fixed/non-existing, I will remove all these bugs reports
and also the hint in
src/CMD/generic/POST_INSTALL.sh
Hope this is o.k. with everybody!
PS: A google search tells us about such problems at least in the past:
http://gis.itc.nrcs.usda.gov/archive/GRASS-output_dir/msg00017.html
these strings.
Radim
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
