[GRASS5] ps.map colortable bug
I'm trying to track down a bug in ps.map's colortable instruction.
Category based maps won't draw category labels (at a readable size) without
setting "width" to something (big).
This works fine in 5.4 (ie you don't have to set width to use cat labels).
I've tracked it down to this code in grass6/ps/ps.map/r_colortable.c:
    if ( w > 0 ) {
        ct.width = w;
    } else {
        ct.width = 2 * ct.fontsize / 72.0 ;
If I comment out everything but "ct.width = w;" it works fine.
(after this in ps_clrtbl.c it auto-sets the width if not given)
Does anyone have an idea what this code is trying to do?
Perhaps it is trying to do & missing char_width*strlen(longest label) ?
I'm hesitant to rip it out without knowing what it is trying to do.
thanks,
Hamish
without setting "width" to something (big).
Fixed in CVS. Code for autosizing the floating point colortable snuck
into the option parsing code which made it not use the category based
colortable autosizing.
Hamish
