Hi -
Is there any reason why ps.map draws grid lines before unmasked vector areas?
makes the output look funny..
from src/ps.map/ps.map/cmd/ps_map.c:
/* do the masked vector plots, if any */
if (vector.count) do_vectors(0);
/* do the masked ponts/lines, if any */
do_plfile(0);
/* do masking, if required */
PS_make_mask();
if (PS.mask_needed)
do_masking();
/* do the grid, if any */
do_grid();
/* do the unmasked vector plots, if any */
if (vector.count) do_vectors(1);
/* do the sites, if any */
do_sites();
/* do the grid numbers, if any */
if (PS.grid_numbers > 0) do_grid_numbers();
Shouldn't the grid lines come just before the grid numbers?
ta,
Hamish
