[GRASS5] ps.map supports grassrgb
I have tried to add grassrgb instruction in ps.map module. See the
diffs and sample figure in the attachment. Also lib/vector/Vlib/area.c
should be patched (but it is part of d_vect_rgb_column.diffs...).
Best regards, Martin
(attachments)
ps_map-grassrgb.diff.gz (4.47 KB)
rgbmap.eps.gz (1.96 KB)
area.c.diff.gz (227 Bytes)
