[GRASS5] purpose of "format" field in cellhd?
Hi developers,
On Tue, Jul 31, 2001 at 03:01:44PM -0400, Justin Hickey wrote:
Anyway, the reason for the mail, I have a friend who is trying to import
Grass 5.0 raster files into other software, and he needs to know what -1
means for the "format" field in the cell header file. I can't seem to
remember and the programmer's manual does not indicate what a value of -1
means. The value usually indicates how many bytes are used for storing the
data but the minimum value seems to be 0 (which means 1 byte). Any idea of
what -1 indicates?
as things are not fully set up here, I would like to ask you for an
answer which I can forward to Justin... I just can't remember the answer.
Thanks in advance,
On Thu, Aug 02, 2001 at 05:16:49PM +0200, Markus Neteler wrote:
Hi developers,
> what -1 indicates?
Floating point. Means look in fcell/<raster>/ for the real deal. Some
"other software" may not handle this scenario (I know MicroImages'
TNTMips doesn't -- though it does do 4.x style CELL).
Eric G. Miller <egm2@jps.net>
> Hi developers,
> > what -1 indicates?
Ah - thanks. I have updated the programmer's manual (chapter 5) accordingly
and fwd'ed to Justin.
