[GRASS5] Q. How do you find the islands for a given area?
please d'nt send any message after that
-----Original Message-----
To: grass5 <grass5@geog.uni-hannover.de>
Date: Thu, 25 ÝÈÑÇíÑ, 2001 09:35 ã 01:00:00 +0000 (GMT)
Subject: Re: [GRASS5] Q. How do you find the islands for a given area?
On Sun, Feb 25, 2001 at 09:25:25AM -0800, Rich Shepard wrote:
On Sun, 25 Feb 2001, Eric G. Miller wrote:
> The biggest killer is the search for the closest tie point between the
> outer polygon and it's inner islands.
Eric,
  Do you know which objects are islands in which bounding polygons? If
so,
my suggestion of a short time ago can probably be modified to comparing
the
minimum x values or maximum x values of the two polygons. Then look at
the y
values.
Yes, v.support would have already identified the 1st generation interior
islands for each boundary area. One thing I did that help enormously
was to remove duplicate points. I'm working in converted screen
positions, so it's often likely that what would
otherXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXX
s. Many of
these algorithms are implemented in the vector library already. It's
just sometimes hard to follow the code.
Eric G. Miller <egm2@jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write
to:
subject 'unsubscribe grass5'
