Dear Developers,
Due to some modification in Grass 6.1, which took place between 25.07.2005
and 13.08.2005, QGIS GRASS digitizer plugin crashes in a situation it used
to handle fine in the past. When a vector file's datatable is edited, which
contains some numerical column *and* a character column, and only the
numerical attribute is filled by the user, while the character column entry
he leaves empty, QGIS crashes in a following way:
QgsGrassEdit::displayDynamic Points = 0x85bacb8 type = 0
QgsGrassEdit::displayDynamic Points = 0 type = 0
No DB record
updated line = 14
node = 27 mNodeSymb = 12
node = 28 mNodeSymb = 12
QObject::connect: No such signal QTabWidget::void currentChanged(QWidget*)
QObject::connect: (sender name: 'tabCats')
QObject::connect: (receiver name: 'QgsGrassAttributesBase')
Value: 14
Value: dbmi: Protocol error
Broken pipe
The datatable of file being edited is described below:
db.describe table=plik_tekst driver=dbf
database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
table:plik_tekst
description:
insert:yes
delete:yes
ncols:3
column:cat
description:
type:INTEGER
len:11
scale:0
precision:10
default:0
nullok:yes
select:yes
update:yes
column:przec
description:
type:DOUBLE PRECISION
len:20
scale:6
precision:18
default:0.000000
nullok:yes
select:yes
update:yes
column:tekst
description:
type:CHARACTER
len:50
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
After I install a Grass version from CVS at 25.07.2005 all is fine. But using 13.08.2005 or 16.08.2005 CVS I get this crash always if I leave the character field empty when editing attributes in a table containing both character and numerical column.
I don't know what is the matter and if QGIS or GRASS is guilty.
Best,
Maciek
