hallo,
it seems to be working. will it support $GRASS_ADDON_PATH in the future?
system: debian - testing.
how is it? is grass going towards Qgis or Qgis towards GRASS ?
I would like to ask, how is it with the new mapcalculator? There is map
called "Output", when I try to perform calculation
| 0 +--------+ Output |
Is resulting to
r.mapcalc =(0)
syntax error, unexpected '=', expecting NAME or STRING
Parse error
Finished with error
Hot to set the name of the output map?
Jachym
On Thu, Oct 13, 2005 at 06:59:56PM +0200, Radim Blazek wrote:
I added shell to GRASS tools in QGIS:
http://mpa.itc.it/radim/qgis/shell1.png
It is very simple pseudoterminal implementing limited
subset of VT100 control characters and sequences.
There is no support for pseudoterminal in Qt, so it starts
in C: seteuid, openpty, fork, execl, fchown, fchmod, etc.
which certainly appreciate all Qt/OOP/C++ fans.
openpty is in libutil (on Linux), so I added check to configure
and ifdef in code for openpty. Other functions should be POSIX.
It does not support vertical moving => impossible to run programs
printing on the whole screen like mc, top etc.
It is very probable that you will find some problems with your
shell/distro/settings combination, please report important unsupported
control sequences.
I am not sure if we can get working without problems in all enviroments,
note that konsole has 19000 lines and I don't want to reimplement/include it.
Links: http://vt100.net/docs/vt100-ug/
Tom, could you find the openpty on Mac and try to compile?
Radim
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
