GRASS 5.7 (probably also 5.3),
$ARCH/etc/colors/gyr:
0% green
50% yellow
100% red
r.colors map=pok color=gyr
-> colr/pok
% 0 255
0:0:255:0 127.5:255:255:0
127.5:255:255:0 255:255:0:0
0:255
i.e. 0 set to white.
Radim
0% green
50% yellow
100% red
-> colr/pok
% 0 255
0:255
Radim
0% green
50% yellow
100% redr.colors map=pok color=gyr
-> colr/pok
% 0 255
0:255i.e. 0 set to white.
Unless someone has changed it, the color= option uses the coded rules;
e.g. color=gyr uses G_make_gyr_fp_colors(), which has the hardcoded
0=white rule.
IOW this bug/feature is in the various G_make_*_colors() functions in
libgis.
> 0% green
> 50% yellow
> 100% red
> -> colr/pok
> % 0 255
> 0:255
> i.e. 0 set to white.Unless someone has changed it, the color= option uses the coded rules;
0=white rule.IOW this bug/feature is in the various G_make_*_colors() functions in
libgis.
Note that the 'r.colors rules=gyr' version has had the '0 white' removed
already. Presumably we can now remove this pre-NULL code from libgis as
well?
Hamish
> 0=white rule.
> libgis.Note that the 'r.colors rules=gyr' version has had the '0 white' removed
well?
I have already removed that in 5.7.
Radim
> > 0=white rule.
> > libgis.
> well?I have already removed that in 5.7.
Radim
Now done in 5.3 as well.
Hamish
