[GRASS5] r.contour question
This is a simple question, but it is not mentioned in the manual
Does r.contour only produce integer output, even if the raster map is floating point?
That is the only way I can explain some funny results I got when trying a demo contour map. The contour map looks fine, but the values do not. There are duplicate values on some adjacent lines and only integers show up in the cat values.
Thanks.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
