I have updated the r.fill.dir (needed to generate sinkless
DEMS) partly to FP: the C-code should manage the existing
raster types now using the idea of Huidae Cho (recently
re-posted by Eric).
However, the core algorithm is Fortran which I don't
know. This needs to be updated to FP as well. For
a Fortram programmer this might be a snap...
The "new" code is now at:
src/raster/r.fill.dir2
I would be glad if someone could look into that. Such algorithm
is quite important (especially to have it accepting FP DEMs).
Many thanks in advance,
subject 'unsubscribe grass5'
I'm hacking at it in a bit....should know how hard it'll be shortly.
It's a part of the swatgrass interface now as well.
Bruce
Markus Neteler wrote:
re-posted by Eric).
I looked at this too to see if I could help. I noticed that main.c
starts an executable called "direct_for". With the naming convention
used elsewhere in the code it seemed like there should be a file named
"direct.f" in the CVS tree, but I don't see one. What did I miss?
Roger Miller
Lee Wilson and Associates
Bruce
the fortran code is in
src/raster/r.fill.dir2/cmd
If you compile, the direct_for and friends are generated:
gmake5
g77 -c fmt_un.f -o OBJ.i686-pc-linux-gnu/fmt_un.o
g77 -s OBJ.i686-pc-linux-gnu/fmt_un.o -o /usr/local/grass5/etc/fill/fmt_un
g77 -c un_fmt_fill.f -o OBJ.i686-pc-linux-gnu/un_fmt_fill.o
g77 -s OBJ.i686-pc-linux-gnu/un_fmt_fill.o -o /usr/local/grass5/etc/fill/un_fmt_fill
They go into $GISBASE/etc/fill/
Maybe this code doesn't meet the naming convention, so feel free to rename
the files. It's code from Srinivasan (1991) which I copied from the
src.answers section.
