OK, now something even stranger is happening with r.flow.
I just did a script to create a net erosion/deposition map using USPED. I’ve tested it on the Spearfish data set. It includes r.flow, running from the CLI of course.
If I zoom into to a very small area (205x172), it works like a charm. But if I zoom out a little bit, r.flow bombs with the error below.
If I try the same zoom levels with the CLI for r.flow, it works fine. Both are actually running r.flow via the CLI. However, the script is started from a tcltk dialog. Does anyone have any idea what is going on here? This script is nice to automate a tedious set of calculations.
Michael
Run from CLI only
GRASS 6.1.cvs (spearfish60_valencia):~ > g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4921760
south: 4919710
west: 600720
east: 602440
nsres: 10
ewres: 10
rows: 205
cols: 172
GRASS 6.1.cvs (spearfish60_valencia):~ > r.flow elevation.10m@PERMANENT dsout=test
r.flow Version 13 August 1995, update/fix October 1999
Opening output files…done.
Allocating memory: elevation, aspect, density, e/w distances, quantization tolerances.
Reading input files: elevation…
Precomputing: tangents, e/w distances, quantization tolerances, interpolated border elevatio
ns, aspects.
Working…done.
Writing density file…WARNING: ‘cell/test’ was found in more mapsets (also found in user1).
done.
Closing files…done.
De-allocating memory…done.
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4923130
south: 4918340
west: 599570
east: 603590
nsres: 10
ewres: 10
rows: 479
cols: 402
ns, aspects.
Working…done.
done.
Closing files…done.
Run from script at 479x472 (as above) and r.flow bombs with the following message
ns, aspects.
Working…done.
done.
Closing files…done.
GRASS 6.1.cvs (spearfish60_valencia):~ > r.usped &
[14] 2283
[13] Exit 1 r.usped
GRASS 6.1.cvs (spearfish60_valencia):~ > too many nested evaluations (infinite loop?)
(procedure “GlobalVar::exists” line 1)
invoked from within
“GlobalVar::exists $_widget($path,var)”
(procedure “ProgressBar::_modify” line 4)
invoked from within
“ProgressBar::_modify .progress”
(“eval” body line 1)
invoked from within
“eval ProgressBar::$cmd .progress $args”
(procedure “.progress” line 1)
invoked from within
“$opt($dlg,progress) _modify”
(procedure “progress” line 7)
invoked from within
“progress $dlg $val”
invoked from within
“if [eof $fh] {
close $fh
} else {
set str [gets $fh]
append str “\n”
if { [fblocked $fh] } { set str [read $fh] }
while {[set idx [string f…”
(procedure “prnout” line 5)
invoked from within
“prnout 1 file16”
Reduce region to 205x172 and run again from same script
Works fine
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
