I have committed a change to r.in.gdal to support GCPs. If GCPs are
detected an imagery group will be made, even if normally only a raster
would have been created, and the GCPs are written out to a POINTS file.
The user will still have to pick an appropriate location and mapset to
rectify to with i.target, and use i.rectify to take advantage of the
GCPs.
I also realized that I can't translate signed integers to FTYPE_CELL
because it is unsigned. That means that complex integer bands must be
converted to floating point layers as occurs now, contrary to the
change I tried this morning.
I have tried the altered r.in.gdal with ERS2 CEOS and other datasets and
they seem to work OK, though I found it challenging to visualize the
resulting images. How does one normally display floating point data in
a monitor? I even tried converting the complex images to magnitude and
scaling with r.mapcalc, but somehow I wasn't doing it right. Also, how
do I get information on the min, max, and mean of a raster? I tried
r.info, r.describe, and r.stats but couldn't seem to find what I would
wanting.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
wanting.
Maybe r.statistics, but it seems to be broken (the handshake to r.stats
seems to have the wrong option flags). Of course it's overkill, but with
the R interface, it's:
Min. 1st Qu. Median Mean 3rd Qu. Max.
40.0 62.0 100.0 115.3 167.0 278.0
for the leics topo layer.
Would a small collection of shell scripts to use R for things like this be
any use (R can be run as a back-end)? (I've already written s.kcv
look-alike as an R function).
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
On Wed, Sep 05, 2001 at 10:19:39PM -0400, Frank Warmerdam wrote:
Markus,
GCPs.
great work - I will try this later the day. This is really a help.
I see. Anyway, it's no bug.
Then, important, change the color table with r.colors. What do you (not)
see?
Also, how
wanting.
You can look at r.colors (main.c), it is checking for the range (there is a
GRASS function to get the mean).
Also, how
wanting.
An update here:
on module level there is only the script
r.univar
providing these information. Unfortunately pretty slow as
being shell/awk based.
Maybe r.stats and code from s.univar (C) should be merged to
a new r.univar?
Also, how
wanting.
