[GRASS5] r.in.gdal available
Frank Warmerdam wrote:
I have written a preliminary implementation of r.in.gdal, and have
provided it to someone to tryout. This is a grass command that load
libgdal.1.1.so and uses it to import any GDAL supported raster formats,
floating point or integer. You can find the source, and a bit of info at:
http://gdal.velocet.ca/projects/grass/
From his page:
This is a raster import program based on my Geospatial Data Abstraction
Library (GDAL). It supports import of a wide variety of
raster file formats, including many variations on GeoTIFF.
The current implementation uses dynamic loading of libgdal.1.1.so using
dlopen(), so as to avoid depending on linking against
GDAL explicitly. Integer and floating point rasters are supported; as well
as importing the georeferenced bounds. However, the
projection defaults to the current mapset projection, and category lists and
color tables are not yet supported. I am interested in
ongoing feedback on r.in.gdal and hope to incorporate it into the master
GRASS CVS tree by the end of October/2000.
http://www.remotesensing.org/gdal/
FYI...
subject 'unsubscribe grass5'
