[GRASS5] r.in.gdal bug?
Dear developers,
im writing a small shell script to download and import Landsat TM Layer and other data availible from NASA WMS service into GRASS.
Im downloading the data with wget and try to import it with r.in.gdal. The downloaded dataformat is geotiff.
But sometime after downloading the data, r.in.gdal produce this error:
ERROR 1: TIFFReadDirectory:/home/soeren/grassdaten/Harz/data/.tmp/AMD64bIT/18773.0/Image_global_mosaic_base_visual_2164_3258:
Can not read TIFF directory count
The file is a valid tiff file in a directory created with g.tempfile.
Im working with GRASS 6.1-cvs.
Is this a bug in gdal or in r.in.gdal?
Im using gdal version 1.2.5.
AMD64bIT ~/src/grass6>/usr/local/bin/gdal-config --version
1.2.5
Does anybody else had this problem?
Regards
Soeren
Hello Sören,
On Thu, 8 Dec 2005 01:49:17 +0100 Sören Gebbert <soerengebbert@gmx.de>
wrote:
Dear developers,
Layer and other data availible from NASA WMS service into GRASS. Im
ERROR 1:
Can you try updating to the recent gdal-version (1.3.1) and see if the
error persists with the same geotiff which throws an error right now?
Best
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
On Thursday 08 December 2005 09:16, Stephan Holl wrote:
Hello Sören,
wrote:
> Dear developers,
> ERROR 1:
I've updated gdal to version 1.3.1 with internal tiff and geotiff support, but the error
dont disappear. But after many tests, i found the reason: the NASA WMS server http://wms.jpl.nasa.gov/
dont provide the full dataset sometimes and stops the download bevor the geotiff file is
complete?! Thats the reason r.in.gdal fails.
Thanks for your answer,
regards
Soeren
Best
  Stephan
