[GRASS5] r.in.gdal: gdalbridge bug
I have found that r.in.gdal ignores the LD_LIBRARY_PATH
settings. The reason is that in
src/raster/r.in.gdal/gdalbridge.c
#ifdef __unix__
is used which obviously doesn't exists. Does anyone
know the correct ifdef for unix?
On Mon, Nov 19, 2001 at 07:52:11PM +0100, Markus Neteler wrote:
#ifdef __unix__
A follow up:
Perhaps the LD_LIBRARY_PATH is caught elsewhere. However,
r.in.gdal is currently ignoring the LD_LIBRARY_PATH
settings from the current GRASS session which makes it
difficult to run different GDAL implementations.
> #ifdef __unix__
It's defined by the preprocessor:
  $ echo > foo.c
  $ gcc -E -dM foo.c | fgrep unix
  #define __unix 1
  #define __unix__ 1
  #define unix 1
A follow up:
AFAIK, it isn't ignoring it, but it's only used if the GDAL library
can't be found in $GISBASE/lib or $GDAL_HOME.
For each of the names:
  libgdal.1.1.so
  gdal.1.0.so
  gdal.so.1.0
  libgdal.so.1
gdalbridge.c calls dlopen() on:
  $GISBASE/lib/<name>
  $GDAL_HOME/<name>
  <name>
The last of these will look for the library using the same mechanism
as used by ld-linux.so; i.e. first search all directories in
$LD_LIBRARY_PATH, then look for an entry in /etc/ld.so.cache.
Note: using the configure switch "--with-gdal" should bypass
gdalbridge.c altogether; libgdal will just be linked in as with any
other shared library.
