I tried to import the Europe tile of SRTM/GTOPO30 from GLCF.
There is a small issue which makes GRASS refuse the file:
gdalinfo SRTM_GTOPO_u30_n090w020.tif
Driver: GTiff/GeoTIFF
Size is 4800, 6000
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["metre",1],
AUTHORITY["EPSG","4326"]]
Origin = (-20.000000,90.000000)
Pixel Size = (0.00833333,-0.00833333)
Metadata:
TIFFTAG_DOCUMENTNAME=D:\Kuan\srtm\SRTM30\w020n90_new.tif
TIFFTAG_IMAGEDESCRIPTION=IDL TIFF file
TIFFTAG_XRESOLUTION=100
TIFFTAG_YRESOLUTION=100
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Corner Coordinates:
Upper Left ( -20.0000000, 90.0000000) ( 20d 0'0.00"W, 90d 0'0.00"N)
Lower Left ( -20.0000000, 39.9999974) ( 20d 0'0.00"W, 39d59'59.99"N)
Upper Right ( 20.0000021, 90.0000000) ( 20d 0'0.01"E, 90d 0'0.00"N)
Lower Right ( 20.0000021, 39.9999974) ( 20d 0'0.01"E, 39d59'59.99"N)
Center ( 0.0000010, 64.9999987) ( 0d 0'0.00"E, 65d 0'0.00"N)
Band 1 Block=4800x1 Type=Float32, ColorInterp=Gray
-> looks reasonable
GRASS 6.1.cvs (latlong):~ > r.in.gdal SRTM_GTOPO_u30_n090w020.tif out=srtm90_gtopo30
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
D0/0: North: 90.000000
WARNING: G_set_window(): Illegal latitude for North
-> I have added debug output to lib/gis/adj_cellhd.c
--> strange, but (using %.10f output):
D0/0: North: 90.0000000002
-> to me it looks like a C problem.
How can I convince lib/gis/adj_cellhd.c to work as desired?
The comparison is currently:
if (cellhd->north > 90.0)
return (_("Illegal latitude for North"));
