[GRASS5] r.in.gdal
Folks,
I have updated r.in.gdal in CVS to first search in $GISBASE/lib for a
libgdal.1.1.so file, and done a simple test.
I have also prepared a shared library for linux for initial testing:
  ftp://gdal.velocet.ca/pub/outgoing/libgdal-linux-grass.tar.gz
This is more or less a normal libgdal but with the following caveats:
o libpng, libtiff, libgeotiff, libjpeg, libungif are builtin to limit
   the number of dependencies.
o libgrass support is disabled (no need for this in r.in.gdal, and it
   might cause all sorts of odd problems).
o No OGR (vector) support, since r.in.gdal wouldn't utilize it anyways.
The dependencies of this library look like this:
warmerda@gdal3[195]% ldd ~/gdal/libgdal.1.1.so
        libz.so.1 => /usr/lib/libz.so.1 (0x40198000)
        libdl.so.2 => /lib/libdl.so.2 (0x401a7000)
        libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3 (0x401aa000)
        libm.so.6 => /lib/libm.so.6 (0x401f0000)
        libc.so.6 => /lib/libc.so.6 (0x4020d000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
The only part of this I don't like is the C++ shared library. It is installed
on most modern Linux system, but some may lack it. If so, grab the following
and put it in /usr/lib or /usr/local/lib (if in your LD_LIBRARY_PATH):
  ftp://gdal.velocet.ca/pub/outgoing/libstdc++-libc6.2-2.so.3
If you update to the latest r.in.gdal from CVS you can just drop
the libgdal.1.1.so into $GISBASE/lib. If you have the last beta you can
still use by putting it somewhere in the library path, perhaps /usr/local/lib.
I would appreciate feedback from people who try out r.in.gdal with this new
shared library. If things go well it should be sufficient to add the library
to the $GISBASE/lib directory in the next binary build, and I am prepared to
build libraries for Solaris and IRIX as well.
I saw in the bugs list problems with r.in.tiff, and r.in.png. Note that
r.in.gdal reads TIFF and 24bit png files.
If all goes well with r.in.gdal, I would also like to implement an r.out.gdal
and eventually import and export programs using the OGR library for various
vector formats. A list of GDAL supported file formats can be found at:
  http://www.remotesensing.org/gdal/formats_list.html
and it includes GeoTIFF, Arc/Info Binary Grid, CEOS (including SAR), DOQ,
DTED, Eosat Fast Format, ESRI BIL (.hdr labelled), GIF, Erdas Imagine, JPEG,
PNG, Netpbm, and SDTS DEM.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
subject 'unsubscribe grass5'
Hi Frank,
as being very interested in your growing GIS libraries
I have tried below improvement:
On Thu, Jan 18, 2001 at 10:34:48AM -0500, Frank Warmerdam wrote:
Folks,
Yep! It is detected.
Frank, just interested: do you *plan* to add HDF support? Otherwise
we would have to re-activate the HDF3.2-r.[in|out].hdf modules which
might need heavy updating.
Thanks for providing GDAL! Of course I will add it to the Linux binaries
as you requested. Only a version problem with libstdc++-libc6.2-2.so.3
may occur (here I had a slightly older version).
Excellent!
I hadn't been expecting to do it within the next few weeks. I presume
you mean HDF EOS support, not just regular HDF, right? If you can patch
up the existing HDF support fairly easily then you should do that. If
it needs a large chunk of work, then come back to me and I can take a
crack at doing it within GDAL instead.
Damn. I was afraid of this. Perhaps we should push ahead to having
$GISBASE/lib added to the LD_LIBRARY_PATH within the GRASS environment
before the next beta, and putting the C++ runtime library there.
Alternatively, if anyone knows an easy way for me to link it in statically
I can try to fix up the shared library.
Best regards,
Excellent!
O.k., so we postpone it slightly. Perhaps it is not too difficult to
update the existing GRASS modules.
This sounds the best at time. Any idea how to do that? I guess
it is to be done in GISBASE/etc/Init.sh (hi Justin).
Best regards,
Hi Markus and Frank
> > binaries as you requested. Only a version problem with
> > libstdc++-libc6.2-2.so.3 may occur (here I had a slightly older
> > version).
> environment before the next beta, and putting the C++ runtime
> library there.
Sorry for the late reply, but do you still want this added to
LD_LIBRARY_PATH?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
LD_LIBRARY_PATH?
Justin,
I did it at the time, but forgot to check it in. It's there now. Could you
glance at init.sh and verify that my approach to updating LD_LIBRARY_PATH is
acceptable?
Hi Frank
Could you glance at init.sh and verify that my approach to updating
LD_LIBRARY_PATH is acceptable?
It looks fine to me, thanks for updating it.
Sincerely,
Bangkok, Thailand
