Hello All,
I'm trying to resolve the r.in.gdal segmentation fault mentioned several
times on the mailing list over the past year. The problem shows itself no
matter what type of raster file I try and import.
My sytem is redhat 9 with gdal/proj/grass all built from CVS.
After installing and/or building and installing several versions of both
grass and gdal as binaries or built from source the problem isn't fixed. If
there is a simple fix I'd love to know it or I'd be happy to try and help
fix the problem.
Tom
fix the problem.
Can you build with debugging support and try
to see what the traceback says?
Check: http://grass.itc.it/grassdevel.html
for links to the "debugging" hints
Are there any versions you didn't build yourself?
Bernhard
> fix the problem.
Bernhard
An important bug was fixed Jan 23 (5.3-CVS), do you use that version?
I did try installing various precompiled binaries as well as building from
source. If the update from 5.3 does not help I will follow up with the
debugging build.
Tom
-----Original Message-----
From: grass5-admin@grass.itc.it [mailto:grass5-admin@grass.itc.it]On
Behalf Of Markus Neteler
Sent: Monday, January 26, 2004 10:58 AM
To: grass-dev
Subject: Re: [GRASS5] r.in.gdal
no
If
help
> fix the problem.
Bernhard
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
