Hi shapefile users,
r.in.shape is now available (based on shapelib, ASCII file and r.in.poly).
Works for areas and lines.
But v.in.shape is main module for importing shapefiles. You should start
with v.in.shape and only if nothing can help you build areas for few days
you can use r.in.shape as I did.
(v.in.shape should not depend on topological problems)
Radim
subject 'unsubscribe grass5'
