[GRASS5] r.info bug with reclassed maps?
Hi again,
also r.info seems to go mad with reclassed maps.
Can anyone confirm this?
BTW: I have moved the search engine to grass.itc.it now
(thanks to Bernhard Reiter for his help). We have a fast
engine now, with full referencing to the "grass5" mailing
list.
Markus Neteler wrote:
Hi again,
Markus, what do you have wrong?
I have found that it does not report the number of categories for
reclassed
FP maps, e.g.
GRASS:> r.info lsfactor
| Layer: lsfactor Date: Fri Nov 2 19:08:53
2001 |
| Title: 1.4*exp(uparea/22.1,0.4)*exp(sin(slope15)/0.09,1.3) (
lsfactor ) |
| Type of Map: cell Number of Categories:
315 |
| Data Type:
FCELL |
However, I have defined only 5 categories - so it appears that it is
using the values in the category file for the number
of categories. Without defining categories the number of categories for
FP map is 255.
But r.info works correctly with the old spearfish files so it appears
that it has a problem only with reclassed
FP maps.
Helena
GRASS:> r.report -C lsfactor un=p
r.stats: 100%
|MAP: 1.4*exp(uparea/22.1,0.4)*exp(sin(slope15)/0.09,1.3) (lsfactor in
helena)|
| Category Information
| #|description |
cover|
| 0-1|stable . . . . . . . . . . . . . . . . . . . . . . . . . . . . |
13.83|
| 1-5|low. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |
35.23|
| 5-10|moderate . . . . . . . . . . . . . . . . . . . . . . . . . . . |
24.78|
| 10-50|high . . . . . . . . . . . . . . . . . . . . . . . . . . . . . |
25.93|
|50-315|severe . . . . . . . . . . . . . . . . . . . . . . . . . . . .
| 0.23|
|TOTAL
|100.00|
list.
grass5 mailing list
grass5@grass.itc.it
<A
HREF="http://grass.itc.it/mailman/listinfo/grass5&quot;&gt;http://grass.itc.it/mailman/listinfo/grass5&lt;/A&gt;
</PRE></BLOCKQUOTE><!-- selection start --><!-- selection end
-->&nbsp;</html>
list.
grass5 mailing list
grass5@grass.itc.it
