Hello Rich and others,
I am indeed working on a version of r.le for
GRASS 5. I have a version of r.le.patch and
r.le.pixel that seem to run fine. The only
serious remaining bug is in r.le.setup. I wrote
to the programmer's list about this one a couple
of months ago, but no-one had a solution. Until
I can solve this one, r.le.setup is unusable.
I also have not yet tested all the parts of r.le.patch
and r.le.pixel to see that the output numbers are
correct.
So, there is some work yet to do before I can
release the new version.
Right now I am in the field, checking email only
every few days. When I return to Laramie in early
August I hope to make more progress.
Sorry for the slow revision, but it is still on
my list to be completed.
Bill Baker
-----Original Message-----
From: Rich Shepard [mailto:rshepard@appl-ecosys.com]
Sent: Wednesday, July 04, 2001 7:56 AM
To: Markus Neteler
Cc: grass5@geog.uni-hannover.de; bakerwl@uwyo.edu
Subject: Re: [GRASS5] r.le in GRASS-5?
On Wed, 4 Jul 2001, Markus Neteler wrote:
William Baker (http://www.uwyo.edu/geog/faculty/baker.html) has been
working on it, however, I don't know if the update is finished.
He may answer this questions,
Thanks, Markus. I know that Bill developed this originally, but I did not
know if it was still alive and breathing. I have a need to use it in a
project, so I'll wait for more information.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) |
Making environmentally-responsible mining happen.
From neteler Thu Jul 5 14:48:40 2001
Return-Path: <neteler>
Received: by hgeo02.geog.uni-hannover.de (SMI-8.6/SMI-SVR4)
id OAA04533; Thu, 5 Jul 2001 14:48:40 +0100
Date: Thu, 5 Jul 2001 14:48:39 +0100
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: andrea.aime@comune.modena.it
Cc: grass5 developers list <grass5@geog.uni-hannover.de>
Message-ID: <20010705144839.B4498@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: andrea.aime@comune.modena.it,
References: <3B433C55.A52B01C9@comune.modena.it> <20010705122255.Q21074@hgeo02.geog.uni-hannover.de> <3B445D1F.CD454BA@comune.modena.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <3B445D1F.CD454BA@comune.modena.it>; from aaime@comune.modena.it on Thu, Jul 05, 2001 at 02:27:11PM +0200
Subject: [GRASS5] Re: s.voronoi updated
Sender: grass5-admin@geog.uni-hannover.de
Errors-To: grass5-admin@geog.uni-hannover.de
X-BeenThere: grass5@geog.uni-hannover.de
X-Mailman-Version: 2.0.5
Precedence: bulk
List-Help: <mailto:grass5-request@geog.uni-hannover.de?subject=help>
List-Post: <mailto:grass5@geog.uni-hannover.de>
List-Subscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=subscribe>
List-Id: GRASS 5 Developers mailing list <grass5.geog.uni-hannover.de>
List-Unsubscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=unsubscribe>
List-Archive: <http://www.geog.uni-hannover.de/pipermail/grass5/>
Status: O
Content-Length: 939
Lines: 29
> Hi Andrea,
> On Wed, Jul 04, 2001 at 05:55:01PM +0200, Andrea Aime wrote:
> > Hi Markus,
> > I've corrected s.voronoi bug, which manifested itself only when
> > there were two coincident sites: now the program uses only the
> > first one and discards all the remaining copies. I also improved
> > label handling, you'll see a description in the package attached
> > (I also updated html man page). I hope it will work pretty well also
> > for you, I didn't have the time to do extensive testing... sorry, it's
> > the best I can do now.
> thanks for the fix - I have uploaded into CVS.
Uhm, I hope it doesn't add other bugs... it would be nice if someone
else woul test try it...
Those being interested in s.voronoi may test the current CVS version.
Thanks (especially to Andrea!)
From neteler Thu Jul 5 14:51:40 2001
id OAA04573; Thu, 5 Jul 2001 14:51:40 +0100
Date: Thu, 5 Jul 2001 14:51:39 +0100
To: Glynn Clements <glynn.clements@virgin.net>
Message-ID: <20010705145139.D4498@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: Glynn Clements <glynn.clements@virgin.net>,
References: <15158.8823.650627.515067@cerise.nosuchdomain.co.uk> <20010625083219.J29754@hgeo02.geog.uni-hannover.de> <15159.19652.187050.234424@cerise.nosuchdomain.co.uk> <20010702225024.A9260@hgeo02.geog.uni-hannover.de> <15169.21789.291611.895541@cerise.nosuchdomain.co.uk> <20010703100656.D7244@hgeo02.geog.uni-hannover.de> <15169.36229.59095.722307@cerise.nosuchdomain.co.uk> <20010703123324.F7244@hgeo02.geog.uni-hannover.de> <15172.3059.210209.27077@cerise.nosuchdomain.co.uk> <15172.19110.280743.178694@cerise.nosuchdomain.co.uk>
Mime-Version: 1.0
In-Reply-To: <15172.19110.280743.178694@cerise.nosuchdomain.co.uk>; from glynn.clements@virgin.net on Thu, Jul 05, 2001 at 12:08:22PM +0100
Subject: [GRASS5] Re: Numercial stuff in GRASS
Precedence: bulk
Status: O
Content-Length: 1725
Lines: 50
Glynn
(cc to grass5)
as your improvements and comments may be of further interest,
I cc it to grass5.
Hi all: Glynn is currently improving the "gmath" lib to add further
maxtrix/vector functionality:
> I'll look at egvorder() and transpose() next (the latter should be
> trivial). The FFT stuff may be less straightforward.
G_matrix_transpose() already existed. I've added
G_matrix_eigen_sort(), which uses qsort() rather than an O(n^2)
algorithm.
I have a few comments about la.c generally:
1. It might be worth providing G_vector_{get,set}_element() functions.
The accessors for vectors are actually more involved than for
matrices, due to the need to handle both row and column vectors and
the v_indx field. OTOH, using such functions would typically impair
efficiency.
2. While G_matrix_init() and G_vector_init() have corresponding
G_matrix_free() and G_vector_free() functions, there aren't any
equivalents for G_matrix_set() and G_vector_set().
3. Passing in an existing vector (or matrix) to receive output is
potentially messy, due to the possibility of conflicts between the
provided and required dimensions, and the issue of whether the caller
or the function is responsible for initialisation. Returning a
dynamically-allocated vector (or matrix) is simpler.
4. There are a number of cases where "const" should be used in
parameter declarations. This is an issue with GRASS generally,
although performance might be more relevant with the gmath library.
Please let us know your thoughts,
From neteler Thu Jul 5 16:32:28 2001
id QAA05142; Thu, 5 Jul 2001 16:32:28 +0100
Date: Thu, 5 Jul 2001 16:32:28 +0100
To: "William L. Baker" <bakerwl@uwyo.edu>
Message-ID: <20010705163228.G4498@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: "William L. Baker" <bakerwl@uwyo.edu>,
References: <Pine.LNX.4.33.0107040654170.28935-100000@salmo.appl-ecosys.com> <BIEKIBLJLPNGFJHLECBDAEILCCAA.bakerwl@uwyo.edu>
Mime-Version: 1.0
In-Reply-To: <BIEKIBLJLPNGFJHLECBDAEILCCAA.bakerwl@uwyo.edu>; from bakerwl@uwyo.edu on Wed, Jul 04, 2001 at 10:39:50AM -0600
Precedence: bulk
Status: O
Content-Length: 2469
Lines: 76
Here is the old mail (I think so):
http://www.geog.uni-hannover.de/mailinglisten/grass5/archive/2000/12/17/7
http://www.geog.uni-hannover.de/mailinglisten/grass5/archive/2000/12/18/1
Perhaps useful to finally help Bill Baker!
correct.
Bill Baker
To: Markus Neteler
Rich
grass5 mailing list
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
